I'd love to get £1 for every poor earth I've known due to rusty or badly made joints.Wago connectors.
How exactly do you envisage the CPC failing, given that it's the steel conduit itself?
Wago connectors.
My MO for radials in conduit has always been to run with 4mm singles (6491). I'd be using the existing cables to pull a full set of 3 singles through as the T&E will be massively derated in conduit, plus the flex is not ideal either.
20A breaker?the T&E will be massively derated in conduit, plus the flex is not ideal either.
The correct cables are used in there respective places, i.e. conduit singles in steel conduit, T&E with solid cores used elsewhere outside of the steel conduit. Its at the socket where a branch occurs and you have three cables connecting at the socket one with a mix of flex and solid core, connecting onto the socket connector that is not ideal.
Not sure what you are getting at.That's where it starts to sound like it's spurred off, which on a suitable breaker should still be fed via t&e if it's in open air.
