Texecom add user can only use Key fob
25 Apr 2011
Hi all.
Having an issue. Texecom wireless..
Going to add user
Master
Enter code... I do that
Area A... only a area
Then i get a beep and it says: Types Custom
I'm sure it used to have options, master, manager etc.
Next is option 1
ADO****F
next is option 2
U***SR*O
Config
CTZSUE**
Locked by timer .....C
I'm trying to remove the C but it just beeps and wont let me
Doo ctl
The it asks to add the tag.
Can anyone help me get rid of the C and also bring back my user types?!?
When I set it I can not disarm using my pin code ...the proxy tag only
Hope somebody can help
that's the process, try doing it from engineers code then.
engineers code
8 setup users
select user
and go through the process
engineers code
8 setup users
select user
Is there I reason I cant change the type to anything other than custom?
Forget that.... for some reason it's gone back to normal.... not sure if it takes it some time to update?!
I have done it all again now and it worked... earlier I did it like 10 times in a row and it wouldnt change.
Thanks for the help
