If the socket is already a spur, the FCU would make no difference - so no point having an FCU.If in doubt there's no harm in coming off the socket via an FCU even if it is just for a TV.
Could I run the cable straight from the back of the socket to the FCU? Then from there to my new socket behind the TV?
It will be "fused down" by the fuse in the plug - an FCU 'protecting' a socket off a spur will do nothing to help.I do agree, but without reading back through the posts I don't think we don't know if the socket in question is already fused down or not. In which case I would be happier knowing that the extended socket is fused even if it is just powering a TV.
The plan is to have 2 double sockets behind the TV. All that will be there is a TV, sky box, and a soundbar. The socket that will be the “donor” is in the corner and all that will ever be in that is a lamp.
Draw the circuit.
Yes, so what good will an FCU between socket 1 and 2 do?A bit basic, but you get the idea.
...but that still would not limit the load before socket 1. The cable after socket 1 is not the problem.Depends on if we're assuming socket 2 is a single or double.
Nothing in the case of it being a single. Like you said, the fuse in the plug would limit the load after socket 1 to no greater than 13A, so no different to using an FCU.
Exactly.Obviously nothing stopping us reaching 26A on a double though. The issue there being the current passing through the cable to socket 1, especially if running something from there too.
Aren't both sockets - either side of chimney - both likely to be on a ring circuit?In an ideal world though it would be good to know if socket 1 is running off an FCU to protect the cable feeding it.
Well, assuming the sockets, from which the spur is to be run, are on a ring, then I would use 4mm² for the spur which could then have as many sockets on it as you like.I'm interested in your thoughts though as I am known for overkill use of protective devices.
