Just plumbed in a Stuart Turner 2bar twin unit having been sat unused for several months.
All Im getting is a humming from the motor nothing else. Ive read its either, Start capacitor, PCB or most likely a stuck pump.
The suggestion is to rotate the pump shaft. I assume this is the shaft onto which the impellers are mounted and would normally rotate freely once accessed?
Having removed the casing at one end the impeller will not budge. Anyone with knowledge of this scenario could you please advise?
Many Thanks
Many Thanks
