Stuart Turner Monsoon 2.0 Twin - Humming
Discussion in 'Plumbing and Central Heating' started by Marty1966, 16 Apr 2020.
  1. Marty1966
    Marty1966
    23 Dec 2018
    78
    Thanks Received:
    Country:
    Just plumbed in a Stuart Turner 2bar twin unit having been sat unused for several months.
    All Im getting is a humming from the motor nothing else. Ive read its either, Start capacitor, PCB or most likely a stuck pump.
    The suggestion is to rotate the pump shaft. I assume this is the shaft onto which the impellers are mounted and would normally rotate freely once accessed?
    Having removed the casing at one end the impeller will not budge. Anyone with knowledge of this scenario could you please advise?
    Many Thanks
  2. Sponsored Links
  3. HERTS P&D
    HERTS P&D
    9 Apr 2010
    13,330
    Thanks Received:
    2,066
    Hertfordshire
    Country:
    Post a picture of what you have done.
    Andy
  4. just pumps
    just pumps
    24 May 2016
    3,070
    Thanks Received:
    519
    Country:
    Hard water area? Thinking the housings had water in them when it was removed. Going to have to force the impeller to rotate whilst using a vac on the outlets or remove the impeller which isn`t the best idea unless you understand the seal behind it.
    • Like Like x 1
  5. muggles
    muggles
    28 Oct 2005
    13,431
    Thanks Received:
    3,104
    Daventry
    Country:
    Unload a can of WD40 on it and cross your fingers
  6. just pumps
    just pumps
    24 May 2016
    3,070
    Thanks Received:
    519
    Country:
    Bit late to displace water, white vinegar better.:)
    • Like Like x 1
  7. Gasplumber
    Gasplumber
    21 Dec 2017
    168
    Thanks Received:
    17
    Country:
    Hg Scallaway is very good for scale.
    Best stuff I’ve used
  8. just pumps
    just pumps
    24 May 2016
    3,070
    Thanks Received:
    519
    Country:
    Never heard of that one, safe to use with rubber? Thanks.
    I use Kil-Roc where I can.
  9. Gasplumber
    Gasplumber
    21 Dec 2017
    168
    Thanks Received:
    17
    Country:
    I’m sure on the open impeller with the housing off it would be fine.
  10. Sponsored Links
  11. just pumps
    just pumps
    24 May 2016
    3,070
    Thanks Received:
    519
    Country:
    I`m not so sure.
  12. Marty1966
    Marty1966
    23 Dec 2018
    78
    Thanks Received:
    Country:
    Problem solved! Decided to take the cover off the opposite side and surprisingly the Impeller was rotating freely, so tried the original side again and it too was now free. Put back together and powered it up and again just the humming, so I figured maybe it was basically overtightened so I backed off the four screws just a fraction and the pump kicked in.
    Maybe just coincidence that it was sitting unused for so long or had been overtightened in the past but for now all good. Thanks for all your thoughts and suggestions appreciate them
    • Like Like x 1
  13. Gasplumber
    Gasplumber
    21 Dec 2017
    168
    Thanks Received:
    17
    Country:
    Nice well done
  14. just pumps
    just pumps
    24 May 2016
    3,070
    Thanks Received:
    519
    Country:
    No such thing as a coincidence in my book. Well done but check for leaks by laying kitchen roll under the covers of the housings for a few days.
    • Like Like x 2
  15. Gasplumber
    Gasplumber
    21 Dec 2017
    168
    Thanks Received:
    17
    Country:
    you never done a job and they try to get you back as a callback because something stopped working that you didn’t even touch
    When I say it’s a coincidence the look they give
    • Like Like x 1
  16. Marty1966
    Marty1966
    23 Dec 2018
    78
    Thanks Received:
    Country:
    Have that in place already and will give it a close looking over in the morning after the showers been run
    • Like Like x 1
  17. HERTS P&D
    HERTS P&D
    9 Apr 2010
    13,330
    Thanks Received:
    2,066
    Hertfordshire
    Country:
    I fitted a kitchen tap for a customer, the following day she phones me to tell me that her bathroom radiator is not getting hot and asks me what Iv'e done, I did laugh a lot and explain they are not connected in anyway.
    Andy
    • Like Like x 1
Loading...
Share This Page
