How to make a flood light strobe?
Thats just delay off, you would need to restart it again after each off.
You need something that recycles and you set both on and then off time, there usually din mountable.
Similar to a belisha beacon but adjustable, if you dont have it flashing too fast i quess it would be safe
There not cheap
https://www.google.com/search?q=del...69i57j33l2.12414j0j4&sourceid=chrome&ie=UTF-8
Fitted in older belisha beacons are
http://www.lightinglocations.com/lights/photo-cells/incidentals/flasher-unit.html
Hope you live miles from anyone else or you'll be really popular with your neighbours :) .
Argos used to do a cheap MP3 player you could set to play on power-on, add that to a Canford Audio rock loudspeaker, a cheap amp and that off delay module & you're laughing
Just call the police, tell them 2 people that are not from the same house are dogging there.
I've ordered an on/off relay. Once its here, I will update this thread.
Andy
You will likely need to connect a switch across the input and output, so when you get a proper incident you want to record, then you can put the light on permanent.
We have called the Police many times, and all we are told is that it is not a important but we will get a car sent round asap. Normally about 2 hours later, by then the bloke has had his happy ending and buggered off home.
Andy
