Keeping it square
Drilling through the copper pipe will weaken it though.
Yes but only drilling through the cross pieces at the top and the weight of the seat will be taken in 4 corners by the legs.
I thought saddle clips looged a bit too flimsy.
Munsen rings don't tighten right up on the threaded part (as far as I know) and school board clips don't often fully grip the pipe.
If the bolts don't work, I'll replace the cross pieces and use one of the above though
You could use this, instead of soldering the fittings...
My mate installed a boiler using it and said it worked fine! (y)
Open the images in any browser.
right click on the image and select "copy image".
Come to the thread and in your post, simply right click and select paste (or use CTRL+V)
To get portions of the images you want to use, on W10 use Winkey+Shift+S then select the area, this can then be pasted.
Unless, of course, you're using a phone, tablet or mac!
haha, I'm not a plumber as you can tell so not an issue for me.
Copper pipe stuff is right popular just now
