- Joined
- 12 Apr 2020
- Messages
- 466
- Reaction score
- 0
- Country
Hi
I have speedfit plastic pipes in my wall which can come out at any height to suit fitting the basin and toilet.
I planned to use a short section of copper pipe horizontally coming out of my right angle Speedfit, attached on a noggin, and then coming out of plasterboard just enough to attach to a right angle isolating valve. For the basin the mixer tap I have has flexible pipes which I think can attach directly to the isolating valve, so that seems simple enough
But the toilet...
- should I use flexible pipe for this too? I read that it may too restrictive for a cistern fill.
- is 15mm to 1/2" is correct? To go From the 15mm isolating valve thread to the toilet inlet. - - - Can I unscrew the nut from one side of an isolating valve and attach a flexible pipe directly to it?
Sorry I'm a bit confused about all these fitting! Any help would be great
But the toilet...
