LED to monitor motor
31 Dec 2003
I have a water treatment plant in my garden that, in winter and bad weather, I do not monitor as frequently as I probably should. The pump should run constantly 24/7.
The unit is isolated by a fused spur which, currently, does not have an led but I am going to replace it with one that does. If the pump in the treatment plant should fail will the led go off or does the led just indicate that the power supply has failed? I would like to be able to monitor the pump remotely.
Advice appreciated.
The indicator on an FCU just indicates the presence of power at the FCU. It would extinguish should the fuse in the FCU blow, but it will not tell you if the pump has stopped operating for a different reason.
You can use a current monitoring relay to tell you if the pump is actually running, and use this to trigger some sort of signalling device such as a light, buzzer or something which notifies your mobile phone.
What you need, is to be monitoring the flow that is being pumped. What is being pumped and what pipe size?
No you can't. A stalled motor will still draw current.
Wrong as normal Winston, and as usual you have not added anything useful to this thread at all.
Why not suggest a better alternative if a current monitoring relay can’t be used? (It can)
FOR GOD'S SAKE. I'M NOT WRONG. A stalled motor will still draw current. What is more it will be a large current as there will be no back EMF. You obviously know nothing about electricity and magnetism.
Read Flameports post. Tell him he is wrong as well instead of picking on me.
You do know that current monitoring relays also operate on over current don’t you?
Flameport is not wrong. Just you.
Flow switch on pump outlet.
I would say that's actually the best solution - since, in the final analysis it is presumably water flow which actually matters to the OP.
One can (despite winston's attempt to confuse) use electrical methods to detect whether or not the pump motor is running fairly normally but, at least in theory, the fact that a pump's motor is functioning normally does not guarantee that water is being pumped satisfactorily (anywhere, or to where it is meant to be being pumped).
I am NOT wrong. This is what Flamepot said, "That is true"
He agrees with me. Either we are both wrong, or we are both right.
You are deliberately picking on me accusing me of being wrong when I am not. Were you the classroom bully at school?
Extract from the technical data sheet of a Schneider branded current monitoring relay which you say can not be use to detect a stalled (jammed) motor.
