repairing wall around back box
If the crack moves when you move the cable, doesn't that imply that the mortar is not dry?
I would change that screw for one less sharp and protrusive.
Edited for clarity.
The cable hasn't been fixed to the wall securely, that's why the mortar cracks.
Is the mortar everywhere else firm? Or has it dried out to be soft and crumbly?
Did you wet the wall before applying the mortar??
Often found the ready mix stuff to be weak, they seem to be light on the cement part. I usually use Hardwall, but only available in 25kg
Ready mix stuff absolutely no good at all for filling chases and around boxes. Or anything really.
So my question now is do I have to dig it all out or just the chasing that's cracked and refill that with my top coat filler?
Please excuse what maybe very stupid questions. But do I fill behind the wires as well as in front and should I connect the switch facia to thw wires first to eliminate wire movement once filled?
You clip the cable to the brickwork with one or two cable clips.
The cable needs to be against the brickwork, so the mortar covers the cable by at least 4mm, to reduce cracking.
So you you will fill over and round the sides of the cable, so no filler behind the cable.
Connect the faceplate after you are satisfied with the filling, once the filler has set.
The box has an adjustable lug so you could level the front up if needbe.
Best to switch it off first though.
