Bricks wider than blocks question
27 Nov 2013
Yorkshire
Hi lads
So bricks are slightly wider than breeze blocks, why is this? I am assuming the slight overlap goes on the inside keeping brick and block flush on the exterior?
I think metric bricks are 102.5mm wide so when used in stretcher formation they are half a brick when allowing for pug.
Probably adopted from 4" imperial which is about the same size.
I just checked and the bricks are 100mm and blocks are 96mm not 100mm?
I thought all breeze were 100mm thick.
So for the slight overlap does this go on inside keeping exterior flush to blocks?
Get a new tape
Agree - partly. Bricks have never been 100mm wide.
Have you measured a block lately Woods? Manu's started sneaking the size down (from a full 100mm) a few years back.
Really? I'll need to check. Or could it be the tape manufacturers? :cautious:
