- Joined
- 14 Jan 2020
- Messages
- 167
- Reaction score
- 2
- Country
Probably at least 25 years old Briggs & Stratton SPP175.british made? Less than 30 years old?
It is. 24mm Vs 15/16"15/16” is about 23mm so quite an obvious difference from 14mm
Good point - looks like I'd have to hold either the cog or the scarifier 'arms' manually to provide resistance. Ideally I'd find a replacement cog, which I can't so far - But the plan is to remove this one from the scarifier and use it for the blades (cog broken). Scarifier and blades are interchangeable - slide in and out.Are you able to lock the shaft that this nut and sprocket are attached to?
John![]()
Yes, Metric is for the "thick" Europeans who find multiplying or dividing by anything other than 10 impossible to comprehend.![]()
