Hi guys 'n gals.
In a nutshell what would you recommend from the consumer unit, 30m to a garage, CU in there and out to an old oil filled arc (stick) welder capable of going from 30 amps up to 180 amps.
At the moment I have CU in the house with 45amp Type C RCBO, 10mm T&E to garage 30m away, old CU with wired plugin fuse (yes, I know, that's crap) then at the moment running off a 13amp 3 pin plug. (again that is probably crap, probably needs a 32amp blue plug and socket?)
At the moment it is tripping the 45amp RCBO, not instantly but more like a delayed trip. I can weld for a few minutes at 100amps and it trips. Resets fine but will trip again after a minute WITHOUT me actually trying to weld anything else.
