- Joined
- 14 Aug 2020
- Messages
- 15
- Reaction score
- 0
- Country
My EICR is not due till next year in a London property I rent out, but being a diligent landlord with tenants that are friends I decided to have the test done. a 20 yr old install and had already invested in replacing downlights with fire rated ones and added an RCD to the CU. But the spark that did this has failed the flat based on:
I have no issue doing essential works as per regs and improving things as time passes, but a £2k bill at a time where 70% of my income is disappeared is not good.
Should I just get another person to do a more balanced report and maybe seek recourse if you agree he has been in excess of the regs? Is a metal CU actually required retrospective fix for an RCD/MCB box?
Benny
- Small gap between water pipes and ceiling (less fire resistance)
- Inadequate unlinked fire alarms (it has mains and battery backed linked smoke alarms on landings, and in-date. I also fitted a CO detector despite this not being regs and am investigating a whole of building system with the other property owners that is agreed in principle)
- Plastic CU in entrance hallway (above std wooden floorboards)
- Cracked fused spur
Benny
