Vokera compact 24 SE High Pressure
Ok, I'm lost... not difficult...:(
depending on the age of the boiler there are different setups with the in built filling loop, some of these can let by when in the, non filling position and if you have the earlier one this might be your broblem
Ok, ill take a pic and post it up, thanks Ian
Pictures as requested. The filling loop is a 15mm stop cock, its brand new and not passing.
Cheers
sorry not what I was looking for, can you show your filling loop please, that stop cock isnot the filling loop, if that is how you top the pressure up that is a total bodge, your installation is very poor but if that is how your system is topped up that is a disgrace
I'm afraid that's it Ian... :-(
Totally wrong if that is your filling device , sorry I cant help you any further as I can only advise on systems that are installed properly, yours is a mess and could be so many things, if that stop cock is letting by that is your problem, hence the regulations that dont allow that kind of install
You could advise what is wrong so that the OP can at least have an idea what to look for when the system has been repaired / re-installed.
No harm in pointing out the errors and/or omissions that the original installer was responsible for.
I have done all the advising I can, I can not guess what else is installed wrong, you get your crystal ball out and you advise him
Thanks, just to clarify, this is a flat I purchased, therefore I inherited the CH system & the installation.
Funnily enough, I've had 2 GS engineers out to look at it, and neither commented on the filling loop or its installation.
I've no wish to cause consternation on here, I thought perhaps it was an easy fix, and from an engineering perspective, I was intrigued what could be causing the issue. I sense some angst building up, which seems to occur on the heating forum. Therefore I will withdraw & thank you for all previous advice.
I will now order a new boiler which will be fitted next week I hope.
