the filling loop and the blacl lever 3 position valve, they are not all the same
Ok, I'm lost... not difficult...
depending on the age of the boiler there are different setups with the in built filling loop, some of these can let by when in the, non filling position and if you have the earlier one this might be your broblemOk, I'm lost... not difficult...![]()
sorry not what I was looking for, can you show your filling loop please, that stop cock isnot the filling loop, if that is how you top the pressure up that is a total bodge, your installation is very poor but if that is how your system is topped up that is a disgrace
as I can only advise on systems that are installed properly, yours is a mess and could be so many things,
I have done all the advising I can, I can not guess what else is installed wrong, you get your crystal ball out and you advise himYou could advise what is wrong so that the OP can at least have an idea what to look for when the system has been repaired / re-installed.
No harm in pointing out the errors and/or omissions that the original installer was responsible for.
