well yeah ok, that's a different argument.
Consider over current protection ATM
Now the question: Should the armoured cable going into the garage consumer unit be connected to a same B32 RCD? Is that ok? or should it be a different RCD?
So I think I'm going with connecting the armoured cable in the man cave to a 32A MCB, which matches the house, the armoured cable is buried inside concrete, but I will earth it.
Apart from the fact that there is no point having a 10 square mm (10mm²) cable if the supply is 32A,There is a 10mm wire for the oven which I will put on a separate MCB.
how much smaller?The downstream must be quite a lot smaller than the supply end
Yes you might be right, it does seem there are different options, and a pro can look at the whole set up in details and advise I guessI think you should get an electrician
OP. In that small CU, you would normally have a (double width) red main switch or an RCD. Do you have either of those already? What brand is that small one
