That’s what I thought but you literally buy one according to the number of gears on your rear wheel. 7,8,9,10 speed etc. The more gears, the thinner the chain links are. If you’re still not sure, get one with the 'missing link' (no tools needed), check it for size, remove any links if you have to and then put it in your pouch. The worse case scenario if you don’t do that is that you may have trouble getting the very highest and very lowest gears (largest front and largest rear or smallest front and smallest rear) but at least you will get home!
