Increasing aperture size in fixed worktop.
4 Dec 2004
Wiltshire
I am replacing an inset hob with a slightly larger one. Any advice on using a router to increase the length of the aperture. It is not possible to get a standard jig in position or to remove the worktop without damaging it.
Use a spirit level or 2 stuck with double sided carpet tape.
Then carefully, a layer at the time route the hole.
Thanks, I had in mind something like that. I am only a DIYer with a 1/4” router, any bit recommendations?
Standard straight bit.
A 12mm will be quicker, but in reality you're gonna take it easy, so no difference.
Just don't use a very small one.
1/4" router may struggle.
Not if it's done in 3or 4 mm stages.
In fact, i would go 2mm for the first pass as the laminate worktop is harder, then 4 or 5mm for the rest which is usually chipboard.
Yes, I intended to do it in very small cuts 2 or 3 mil per pass, 15mm off each end. I am particularly concerned at getting the corners right, have been advised to use a straight flute. (n)
Cancel all that. The hob has just arrived and has chamfered edges! So will not be recessed. I will have to build the front and rear steps up to support the front and rear edges of the hob. :(
