I am replacing an inset hob with a slightly larger one. Any advice on using a router to increase the length of the aperture. It is not possible to get a standard jig in position or to remove the worktop without damaging it.
Standard straight bit.Thanks, I had in mind something like that. I am only a DIYer with a 1/4” router, any bit recommendations?
Unless there's less than 75mm from wall, but then the last bit cod be done by hand.Jigsaw would also do it .
Not if it's done in 3or 4 mm stages.1/4" router may struggle.
