Hyundai brake pipe
17 Apr 2007
2009 i20 1.4 PB has a weeping spot on one of the long runs to the back so on the drive till fixed.
Anyone know what size/standard of pipe and fittings Hyundai use?
Are the in situ jointing tools worth considering?
I would imagine they will be standard metric pipe and fittings. Joining tool is worth considering if the rest of the pipe is in good condition and will be a PITA to replace completely.
I've had a look at the pipes and they appear to be steel due the brown rust. They're insulated and where they've corroded, are behind a plastic cover.
Need to find a tool that can flare steel pipe I suppose.
The red arrow is the point of corrosion.
full
It's going to be pretty tight to get a jointer in there I guess - however, a motor factor will make you up a full pipe if you can get it to them - saves the tool outlay if its a one off.
John :)
I'll call the local factors tomorrow and see what's available.
There's the likes of these which I could use to fit these joints.
Useful parts!
I think you'll have an issue forming single flares with hand held gear under the car if the pipes are steel though.....possible enough with cupro nickel.
Expect to lose 6mm of pipe per flare as well as cutting away the corrosion - it's unusual to have enough spare pipe to do this.
John :)
I've considered various options. If I do joints on the existing pipe, I'll likely have to put a new section in to make up the length.
I'll call the local Hyundai tomorrow and ask about the original pipe.
Access is not an issue, its the long run to the back on the underside of the floorpan and I honestly don't know why the plastic cover was fitted. The pipes are insulated so any sections repaired that will have to be stripped of insulation and a nice coating of grease after job complete.
Will inquire tomorrow what is available and go from there.
I would suggest that you look carefully at the pipe and decide the best place to cut it. Make sure that the section where you will be putting the new male end is as clean as you can possibly get it because once you cut the pipe you will be losing fluid so you need to be prepared with your flaring tool. Also, as soon as you have flared it, blank it off so that you have all the time in the world to work on the "downstream" part of the pipe.
To blank it off, you can use your new double female connector blocked off with a male in the other end and a piece of rubber or something.
I use these.
It's an Avensis.
I've tried every which way to prevent the fluid running out, now I just prepare for it and make sure that I cut the pipe, get the new end on, flare it and cap it as quick as possible.
It's an Avensis.
Blimey- I’d have sworn it was a Mk6 Escort where the felt wheel arch liner holds water and rests on the brake pipe. Had quite a few of them burst when holding the brake pressure on during MOT's.
