Hello,
I am replacing an old double electric oven with a slightly smaller single oven. The old one was hard wired using 40amp cable to a switch box in an adjoining cupboard. The new oven appears to come with a 13 amp cable (without plug). I am assuming this new oven will need to be fused at 13amp so I’m thinking of running a new spur from existing 40amp switch box in adjoining cupboard to a new 13amp plug socket below and wire a 13amp plug on to the new oven cable. (The 40amp switch box will be used to connect up a new ceramic hob). Question is: what sort of cable do I need to run from my 40amp switch box down to new 13amp plug socket below?
