if those in wall oral b chargers are as good as the supplied ones they will get a lot of returns
Although I've had no involvement in this thread (but nor has any other John), is that a reference to me?MK sell a socket outlet which could be fitted in the bedroom (although if John says you don't need isolation, you could fit 2 in a bathroom, into a double box and it look tidy)
Thanks for clarifying!sorry I meant John Ward / flameport. Good tip though about the 3m. Worth considering ...
Indeed, and there's really no reason why they have to be the same toothbrushes with the same charger. As was said early on ...Just buy two toothbrushes the same and share the charger as and when required or is that too simple?
Assuming it's a pair of chargers you want to plug in, why not simply use them on alternate days with a standard shaver socket - the toothbrush battery should last at least 7 days without a recharge.
He said that his wife and himself both had toothbrushes, such that he needed two outlets to plug them into - he said nothing about there also being a shaver, which would presumably have brought his total requirement up to 3 outletsWhere does the shaver plug in!!!!
They generally can't as they are different taps on the same transformer. Also, strangely enough toothbrush chargers are the one thing that only work at 230V OR 120V. A european toothbrush does charge up in the states but it takes forever.
My toothbrush ... at anything between 100v and 250v
Philips.So what make of toothbrush is that?
