I've got a Bosch POF 1200 AE router. So far I've only done minor bits of edge trim, but I want to trim down a table which is too big for my kitchen. This involves cutting the top to size, then rounding each corner to a 4.5 cm radius, then running all the way round with a moulding pattern.
It's how best to do the corners. I understand how to make a template and think I could do the job were it not for the 35mm thickness of the table top. Most of my bits are 1/4 inch shank, but I think it will take larger bits up to 5/8 inch, if there is such a size.
The largest bit I have has a 25 mm long cutter with a bottom bearing. Is there any way to use this perhaps with a double pass or alternatively can anybody recommend the correct sized bit from a reputable supplier? I'm a bit dubious about some of the ebay offerings from China.
