- Joined
- 8 Nov 2020
- Messages
- 27
- Reaction score
- 1
- Country
No, not touched the big buttonif you press the middle of the heat link it brings the boiler on, I cant remember if for a timed period or permanent so are you pressing the heatlink ?
Just a noraml manual stat Chris
2 wires from the old stat goto T1/T2 (they change colour by the boiler to black/blue) 2/3 on the heat link goto the RT24v on the boilerThe 2 wires in this stat, live and switched, are these the one that connect to the 12v in heat link and to the nest stat?
Yes mate same place as the old one, tested all wiring and all have power/connected....Hard to tell from photo, but is the nest thermostat in the same position as the last one? Have you tested any wiring, inc the 24v side at boiler? Could try the 230v rt side if the previous thermostat worked?
If it's ok to try i'll give it a go, just take the RT from then 24v side and connect it to the RT 230v near the mains power in ?Well maybe you need to contact Nest support, it’s not something I’ve had before. As I said, maybe,connect up to mains side, just n case your 24v side is goosed.
