Hi folks. Looking for a quick confirmation here.
In the morning I have to join a length of 10mm OD pipe to 15mm OD chrome.
I’m planning to use soldered end feed fittings (obvs I’ll remove the chrome first).
but looking through my box of fittings as well as screwfix and tool station there doesn’t seem to be an obvious fitting to use. I can’t find a 10mm (ID) female to 15mm (ID) male. The closest I can find, which I happen to have in my box, is a reducer which has a 10mm female socket and a 15mm male socket. If I used this then I’d have to use a 15mm-15mm straight coupler slid over the top and then the whole setup soldered in one hit.
Is this the normal way of doing it, or am I missing something obvious?
I do have a 15-10mm conex coupler that would work fine. But it’s going under the floorboards, under tile so I can’t risk it weeping.
thank you.
thank you.
