Hi all,
I wonder if someone in the know could provide me some electrical advice. Today I've had a company install a Zappi 2 charger for my electric car at my home address. I wanted the supply to come off the main CU board as there was a spare way. The CU is a cheapy split load BG board (apologies to the Hager gang).
The install went well to begin with, around 13m of EV Ultra 4mm2 SWA was ran through my basement and out to the Zappi. The SWA was connected through to a 40A MCB (and in turn through one of the RCDs).
When the installer powered up the system, he said that both RCDs in the CU instantly tripped. This happened every time power was applied to the zappi circuit.... I left him to it to figure it out.
Some time later, I caught up with him as he was putting the cover back on the CU. He said that he had spoken to Zappi who has advised him to connect the Zappi supply in to the feed side of one of the CU's RCDs rather than via the MCB and load side of the RCD.
I was becoming concerned about what overcurrent protection would be in place to protect the SWA cable, but as I was unsure of my concern, I didn't raise this with him.
After he left, I phoned Zappi to ask if this method of connection would be permissible. As I feared, they confirmed that the Zappi and supply cable must be protected by an MCB of correct type and rating (as a minimum, with an RCD also being required if the cable is being buried or otherwise not visible).
I didn't feel confident in calling the installer out at the time, call me a coward.... he was meant to be the qualified electrician not me.
I've arranged for an independent electrician to come and have a look and advise. I've also emailed the company for their response, so I wont name them until they've had a chance to rectify.
What are your thoughts? Am I making a mountain out of a mole hill here?
Many thanks,
Matt.
(p.s. I've got a keen interest in electronics, but have an overriding respect for those who are qualified!)
Many thanks,
Matt.
