My front door has ended up with a small gap at the bottom opposite the hinge side. It appears to be a butt-style hinge from Googling a bit. It looks like the bottom hinge has drifted out of alignment of the middle and top hinges creating this gap. I've mucked about but really have no idea what I'm doing and afraid I'll just make it worse.
I can see there is a compression screw at the top and two screws on the side which are incredibly tight(compared with the compression screw). Both have dots on the screws that were pointing towards the frame which I believe means neutral position. The compression screw looks to be in neutral position too.
What is the best way to get this hinge back into alignment (i.e. bring the hinge inwards, towards the door to straighten it up). I tried to move the compression screw which helped a little but its still out of alignment.
