- Joined
- 8 May 2017
- Messages
- 10,649
- Reaction score
- 2,870
- Country
Just curious ,how have you fitted the thermocouple inside the tank ?
A note about that particular thermostat ... the over temp cut-out can't be reset until the thermostat is COLD. I thought I'd found the problem when I found the over temp cutout tripped & it wouldn't reset (tank is also heated by the central heating). I removed the thermostat ready to replace with another & decided to have one more go before I threw it away ... it reset.
The thermostat has been replaced, twice, so it isn't just a bad 'stat (although it could be a batch problem).
I wonder if your boiler is taking the water over temperature?
Keitai ,the post about thermocouple has nothing to do with your set up .
Have you not tested the voltages at the immersions thermostat yet ?
Using the multi meter on voltage setting (as in photo) dont you put the probes on positive and negative terminals to check it's live? Do you put them on the screws which hold wires in place (as in picture)to check? Trying to find out if the controller is live and also if it's working
No.Is this done by setting multi meter to 600 ac as in previous picture on this thread then putting probes as in this picture
No.
If you have to ask questions like that, you should not be attempting any measurements of anything.
Yes to multimeter set to AC 600 volt range.
Black probe to the terminal on right side of pic,red arrow, ( this has the blue wire connected to it ) ,and red probe to left , red arrow,terminal with the white wire connected to it.
You should get 230/240 volts.
If you don't ,leave the black probe on the terminal quoted above ,and put the red probe on one of the terminals with blue arrow pointing to it ,the right hand one. you should get 230/240 volts there .
