We have just moved into a new house (not new build just new to us) and the heating system seems a mess, or we just are not using it correctly.
There is an Ideal Logic+ boiler providing central heating and hot water via a tank. All the downstairs radiators apart from the hall have TRVs on and we think should be controlled (along with the hot water) by the program box next to the boiler - no temperature settings just on/off times.
The problem is that the downstairs rads never switch off. Well we can turn them off with the valve, but whatever temperature they are set to they maintain that day and night. We had a heating engineer come out and told us that we need to replace all the valves.
He said that a broken valve would send a demand for heating to the boiler causing it to be running 24/7. I'm happy to be proven wrong but I'm calling bullshit on that. Surely if the timer control was working then it shouldn't matter how cold the radiator got it should not switch on during the 'off' time?
He has also told us that the loud noise our boiler makes (all night long as the rads don't switch off!) is perfectly normal and the fan on many Ideal boilers does this, whereas I have seen that Logic+ have been certified QuietMark and I've seen reports they are among the quietest on the market.
(There are separate controls for the upstairs radiators - no TRVs, the thermostat is in the bad place but does work, the timer works fine and neither of the timer devices has any effect on the downstairs rads.)
Any advice please - not feeling confident about the advice we have been given but don't want to spend another £100 on another call out for a second opinion if he is right.
