Boiler filling loop not filling!
One side will cut into the cold main leading up to your boiler, other will cut into return pipework back to boiler. This will override the current method of filling.
Unfortunately I still don't see where an external loop would go. The photo in my original post shows all the pipework I can access?
No access to pipes elsewhere? If not, you may just have to renew the existing one.
No, the only pipes are the ones showing in the original photo. So exactly what is it I need to replace then?
Hi
can you tell me vaillant boiler pressure problem no filling loop.
