Storage heaters... asbestos?
The list doesn't require serial number, only model number.
You can remove the front cover without disturbing any insulation to find the info.
Is there nothing under the flap or on the bottom lip next to where the flex enters the heater?
They look to new for asbestos ones
Yes I agree, I've just removed older looking heaters.
Looks like the Unidare WMF/S range way too modern for asbestos me thinks.
Often on a label underneath or by main cable input. Should not need to remove cover.
My Dimplex NSH's had the label at the bottom with all the wiring and ceramic chock bloc's, very much inside the front cover.
