B
Bodd
Hello Sam
Marked red cut with hack saw.
In blue with a Fein saw cut the collar about 5mm. With a heat gun heat litely between the blue lines.. and gently peel with a flat nosed screw driver.
Once that section is removed gently heat an peel the rest. Your heating the collar nit the pipe.
It's an easy fúck up so take your time or get a good plumber
