I’m fitting 2 LED batten lights in my loft. My plan is to have 1 cable coming from a power supply (plug) in to a junction box then 2 cables out, 1 to each light.
I have plenty of cable, 1mm 3 core flex and 1mm twin + earth. I’m inclined more to use the twin + earth because I already have a load of clips to clip it all up neatly, but that’s the only reason. Would I be better using 3 core flex?
if I was to use 3 core flex, what size clips would I buy?
The power lead will run from a plug to the junction box, should I use 3 core flex for the who lead (because I’ve never seen a plug fitted to twin + earth) or should I use twin + earth, fit another junction box and make the last part with the plug 3 core flex?
Thanks in advance for any help, advice or pointing out any errors.
Dan.
Dan.
