- Joined
- 6 Oct 2010
- Messages
- 126
- Reaction score
- 4
- Country
So we've had the hall and landing taken back to brick as the original lime plaster had blown and cracked badly in corners or was hole sounding and was coated with a Chrysotile artex skim that was damaged in places.
We had a professional asbestos company do this work a few days ago, who fully sheeted off the area and used a wet removal product on the artex first, plus double bagged and disposed of it all correctly. Had the old skirtings removed too.
Now we're dealing with a new problem of living in what feels like a derelict house with radiator removed in the hall so it's freezing in there! Electrics are hanging everywhere.
The external wall up the stairs is solid brick and north facing but is fairly sheltered by the next property that also reflects a lot of sunlight onto the wall due to there's being painted white.
I was hoping to take this opportunity to insulate the walls and ceiling before plasterboarding over (our plasterer insists dot and dab is fine for this with batten and board for the ceiling.
However the space between the stair string and brick is only 25mm and to insulate would need 40mm in total, due to 25mm insulation board plus 12mm plasterboard and 3mm skim. We'd therefore need to have a faux stair string made and lose stair width. Our plasterer said this would be very expensive and beyond our already heavy spend.
He said once we get it all boarded and the holes closed in the landing ceiling (old defunct air exchange system, which was taking heat away) to be removed and an insulated loft hatch fitted that it will be much warmer. But our energy and heating bills are very high! £6.50 a day in cold weather!
Also there are deep voids between stud walls of lath and plaster of empty space. Would it be a good idea to put insulated board in between studs? Would that help retain heat in those rooms?
If at the bare minimum we batterned and insulated just the area around the front door and later got a composite door, would that help retain heat?
We also need to upgrade insulation in the loft.
Any advice would be appreciated!
