Hi guys
hoping for some advice from the experts before I call someone in.
S-plan system, has been working ok for a few years. Grundfos UPS2 Pump gets power via the boiler (Vaillant EcoTec+ 418... about 6 years old).
The problem: twice now, the pump got stuck on running continuously. It's not the usual pump overrun. The pump symbol on the boiler screen is off (normally on during over-run). No heating/water demand... just keeps going.
This happened previously a month ago. I suspected (from reading forums) a PCB fault, but after repowering the system (after a few hours), it went back to working and worked fine till now.
Is this enough to eliminate the PCB as a possible issue? Could it be a pump fault?
Anything I could check?
Switching off/on after half an hour didn't fix it this time (pump comes on immediately as I repower).
thanks!
thanks!
