Toilet Fitting Question
1 Sep 2011
Essex
Would this toilet be suitable for fitting in my cloakroom? Would the fact the soil stack is to the left be a problem? I assume I would need to cut an entry on the side of the back to wall unit?
TIo9lgCd4_WQrBiG5iYxX4-xsGUOeLWCT3FAx5w2VbhpvTK90RNNiXe9daearUcimzT0oEoXCA53VE-P7JqgRRSwzSlBQVzFWijz8MS9Muc5ekOmS9L6KJYI3_tYJv1eBtdmho_UvQECkdPI_AbezsZEiPouKqoZJ8QcJKqh-4U8_XF6Fg2fNLnceUZVMDM2zgQRvv0toAiQE0chJplJiJzuCO2D0VpPU6O4jBi0kJeUNAc8iH_bA1ceIDVK3VR-W8NoOBdXzS-5XPYAk10bN9bNyGcAolIi3q3PpugwPvktkVsMxCzxTmNBOTLLa4gxtF5HUsHKhI9sfkIEmA7Hv1cBJv1_EoSakbmclde-fyDepCstdBhLvAW_lqfrMCnf_9ZC7CaHF8dFd4v0VaOzMcEA1ZWyBG05skbrv8FeJ4kiJCYuwsBKg2jeMCfVA3xwpnUDpvPnvqjR4S10FELSzBxENIy_0e-l3oTlkJN5APtJMfsDHzEOsdvtQ1zkM5IkRRmg2p9lv7Ej06zB4Zqm3Lb3WwOewV8LDV8oJB-cJSTzezVlxPgS05o1AFSlOeW6Za6ID8UA7kunUsO8b2cTAJdE8TFWoCurI9V5cw6oo_o2fDjgJdPeRUnGdf-pamUq5G9RBRqsZvTHW7EdYy_H3lI2bYlsdgGnKfQdnSEpQJTFtB7gH6GRwflojag10Kr8297uboe8BCSu6GSIJ6jiWFVo=w430-h907-no
Note , Just a DIYer
i had a very similar setup in my ensuite and the range of furniture included options for side access for the soil pipe.
And I also had a width where the unit fitted next to the soil pipe, and then i boxed in
I also fitted a small basin to the side , so had some worktop space with window sill.
So not the same unit as your BTW with a basin included on top
will you have hotwater available
Note , Just a DIYer
I think these toilet sink combo units only have a cold supply.
oh OK, not sure of the specific version you are getting, but the ones i looked at for our cloakroom and ensuite had a mixer tap , but we decided to change the shower door and fit a separate basin rather than lean over the toilet, so ended up not looking really that close to the spec
Our space is quite restricted so we don't have a lot of choice, having seperates won't work
It's amazing what you can fit in a small space. This is one I installed for a customer in a 900mm wide room.
That looks great! I did look at those, but our space is less that 900mm!
When you install these, would you say where my soil stack is, is an issue? Presume I just cut a hole in the side of the unit, then box in the soil pipe and hole and maybe tile.
