In view of some of the slightly 'confrontational' responses I've been getting, I think I should attempt to clarify my position.
There are very few certainties in all this (but see below **), so, just like everyone else, I cannot and would not attempt to claim that I know what is, or isn't, going to happen, and most certainly would not (apart from the ** below
) 'assert' anything, in any direction.
However, I have spent most of my professional life having to consider not "what is likely to happen" but, rather, "what might happen", and do what I can do to judge (and ideally roughly quantify) how probable (likely) it is that things which "might happen" actually "will happen".
Given uncertainties, my inclination (and 'upbringing') is to be cautious (i.e. err on the 'side of caution').
As I keep saying, in the current situation, essentially all of our faith/hope is being put in the belief that increasing immunity due to vaccination will 'turn things around', and negate deteriorations due to other changes. It is inevitable that will happen to some extent, but we really don't know to what extent, and over what time period, that will happen - and nor do we know what degree of population vaccination (hence immunity) we will ultimately achieve.
I would be much less nervous about what is going to happen on Monday if I had seen at least some signs that the increasing roll-out of vaccination was at least starting to slow the increases - but, with little over 48 hours to go, I still only see the converse (accelerating increases). That's why, for what it's worth, I would probably have advised that the upcoming 'Freedom' should have been delayed at least until some signs of an effect of increasing vaccination was being seen (without those additional relaxations).
[** amidst all the uncertainties, there is at least one certainty - that, if nothing else changes to counter it, a relaxation of measures designed to reduce inter-personal contact/proximity will result in more infections (followed, in due course, by more hospitalisations and more deaths). I can't tell you how many more infections there will be, and obviously hope that it's not too many, but it is inevitable that there will be some ]
