Scanotronic 9448+ zone lights on after powercut
13 Jul 2021
Hi all
Last month my postcode suffered a power cut and my alarm went off. I could not silence it for about 20 mins until Google search led to me inputting 1234 as the default code. This worked
Since then however I cannot set the alarm to work. It just would set the alarm going off everytime I inputted the code to activate the alarm
I did more googling and read threads on here and deduced it must be a faulty battery. So I replaced the battery with a new one. I left mains off for over a hour too incase that helped. Now when I set the alarm the zones 4 5 6 are red and then alarm goes off internally not externally anymore.
I cannot see any issues with the sensors bar perhaps a few cobwebs. Any ideas on whay I could try next or will I need to call out an engineer?
Thanks!
Firstly are zones 45 and 6 PIR's or other powered devices.
Mains power off means you would be running on battery only.
if 45 and 6 are powered devices you may have a blown fuse
Hi Thanks for the reply
I removed the new battery and turned mains off for 1 hour before putting battery back in and turning mains back on
They are infra red sensors in the corner of rooms and the light still comes on if you walk past it
I have attached a pic just incase I have got it confused.
Well if pir lights up then the fuse is good.
Post picture of keypad/ panel unset.
what are on zones 45 and 6?
4,5 and 6 i assume are 2 living rooms and upstairs. They are the only sensors I have in the house
I have posted 3 pictures
One is the keypad in normal state with 2 green lights one top and one at bottom
The other has 1 red light that flashes between numbers 4 5 and 6 for 15 seconds once you press the keypad code to set alarm
And final pic is all 3 red zones lit up whilst the internal alarm sounds
They are probably unused zones and panel has defaulted back to used zones …..open up the panel and see if there are any wires in these zones …. If not either put in a link or program as not used !
Sorry what do you mean by put in a link?
I will try ommiting the zones and putting the alarm on and get back to you.
Ok looks like you were right and they are unused zones. When i omit them and put alarm on and trigger it in different rooms the zones are 1 2 and 3. So it looks like I can now set the alarm at night at least
Any idea how I get the panel to realise they are unused zones as default so ibdont have to specifically omit them every time?
0 enter ( or tick ) 7890 ….all lights flashing engineer mode ….15 enter , press 456 lights go out enter , 99 enter back to normal mode
Thank you so much that worked
Issue resolved!! You guys are great! Thanks So much
Hi
Just to revisit this seems issue is not fully resolved. I can now set alarm perfectly normally but when the alarm is triggered it goes off ONLY internally. Nothing can be heard from outside
Any ideas? Assume it is linked to original power cut detailed in original post of thread
How long did you wait ….did you activate an entry exit zone ? As this has a 30 Sec pre alarm ( it will go off inside but there is a 30s delay before the external bell activates)
Thank you
It stays internal once set whilst I am inside and moving infront of sensors but when set and entry/exit is triggered it does go off externally after 30 seconds
Thanks again
