C
Captain Nemesis
Husqvarna ?Husqvarna recommends not to use high octane petrol, I take this means super 99 .
Can anybody give me the answer ?
oh, an old Fiat fire engine, with no engine management system?
unless you have an accelerator pedal that you can press.lower power output
My car says "Vehicles with a petrol engine require the use of premium unleaded fuel, with a minimum octane rating of 95 RON. Using the correct fuel specification helps to maintain the vehicle's performance, fuel economy, and driveability.
If premium unleaded fuel is not available, use unleaded fuel with a lower octane rating, down to a minimum of 91 RON. Using lower octane rated fuel may reduce the engine's performance, increase fuel consumption, and cause an audible engine knock and other driveability problems."
I don't think I've been offered fuel unsuitable for my car anywhere n Europe.
...you should run them on 98 or higher if you want the performance and economy...
But if you are driving on the road (not the racetrack) under normal conditions, you will never be using anything near 100% of nominal power.
What does it matter if you are driving at 60, using 16% of a available power, rather than at 60 using 14% of the maximum you might have had with a more expensive and polluting fuel.
Just as you will do if carrying a portly passenger rather than a thin one, or the weight of a full tank rather than a half-empty one, or driving on an incline rather than the flat, you, or your automated controls, will simply put your foot down an infinitesimal amount without even noticing.
That has nothing to do with your original argument
Yes it does.
What will your car do if you put 95RON fuel in it?
Run at a lower power output
That's what I said.
Do you know the reduction in peak power?
less economical
I think you mean "use marginally more fuel"
Bearing in mind the extra cost of your superduper petrol, this is not the same thing as "more economically"
Your original assertion was that only old vehicles without ECU require high octane fuel
Why not just fill the 10 litre can with low octane fuel after you have filled your car with high octane fuel or are you in that much of a rush when buying fuel?Husqvarna recommends not to use high octane petrol, I take this means super 99 .
I filled my 10lt can when filling my car should I use this ???
My Machines Honda Mower, Brigs & Stratton mowers. Flymo petrol mower.
two stroke Mix Stihl hedge cutter and jonsered hedge cutter
Thanks.
