Sockets on far wall, isolators on RHS.
The cable sizes vary as per first post, as do the breaker sizes. IIRC:
1 x 16a on 2.5mm
2 x 25a on 2.5mm
2 x 32a on 4 or 6mm, have to check.
Would only be able to use the 32amp ones for my 20 and 32amp machines I believe?
Wouldn't be interested in doing anything major DIY but if changing the sockets is all then might be happy to do that, otherwise if using a lead in the short term is possible I'll do that until a spark can get in to make amendments.
Neutral is present.
I did consider swapping the sockets over to single phase ones and fitting wagos but wasn't sure what was best.
1 x 16a on 2.5mm
2 x 25a on 2.5mm
Neutral is present.
You could just change the 3 phase socket, to a single phase socket.
Put the spare 2 phases into wago blocks.
Regarding fusing. I guess what is being said is if you fit a 16A socket, maybe you need to fit a 16A MCB at the distribution panel? or maybe you don't. I'm not sure.
