Old Honeywell to New Thermostat wiring...
you are hi-jacking an old post, against site rules and for good reason, you will only get the correct answers if you start your own post
sorry I am new to all this, I don’t know what to do, i just wanted to confirm something with the op
No problem, the OPs origional post got quite complicated, and not the normal , so anyone reading gets confused with their set up and yours, hence why , ask for your own set up, post as many pics as you can , and you will get the answers you are looking for , pics give a lot more information than anything else
Thank you
my set up is exactly the same as the op, i just wanted to confirm that in the end this worked for him?
Boiler 3 (L) to New Stat 4
Boiler 5 (N) to New Stat 3
New Stat 4 (L) connect to New Stat 1
Boiler 4 (SL) to New Stat 2
Read more: https://www.diynot.com/diy/threads/...thermostat-wiring.556235/page-2#ixzz75tRIhKT8
As said Pics are best, all boilers use different numbers , and wire colours can never be trusted in heating systems, pics are your best friend
I havw the oictures in my fone gallery, how can i put them on here? Sorry im a novice!
Which button is for pictures from fone?
Same as any other method, upload a file. Also, I thought it was agreed to start a new thread? If you want to know that, click the sub-forum of where to post, eg: plumbing and heating, and then there’s should be an orange button a little way down on the left.
I don’t want to start a new post as people might not know the answer, that’s why i wanted to get the information from the op as he found the answer. Thanks anyways guys.
You dont understand , the origional OP didnt, he had origional installation issues, , but if you dont want the correct advice then that is fine, some people cant be advised
  • Thanks
Reactions: CBW
The op did find the answer didn’t he? I have attached the bit where it worked i just wanted him to confirm!
