Hi, I'm part way through having a boiler installed, and in a main valve and another compression joint my heating engineer has used a LOT of green goo that I think must be Boss Supergreen. There are gobs of it inside the ends of the pipe and in the valve. Like, you could make a cube of it 1cm on each side, kind of thing, in a 35mm pipe.
It's not water soluble of course, immediately anyway, and it seems to me you wouldn't want it in your heat exchanger. What do you think? A problem or a non-issue? I can fix the joints but wondering how bad a sign it might be.
