    Dismiss Notice
Boss Supergreen inside heating pipes
Discussion in 'Plumbing and Central Heating' started by Nigel R, 14 Sep 2021.
  1. Nigel R
    Nigel R
    7 Feb 2021
    24
    Thanks Received:
    3
    Country:
    Hi, I'm part way through having a boiler installed, and in a main valve and another compression joint my heating engineer has used a LOT of green goo that I think must be Boss Supergreen. There are gobs of it inside the ends of the pipe and in the valve. Like, you could make a cube of it 1cm on each side, kind of thing, in a 35mm pipe.
    It's not water soluble of course, immediately anyway, and it seems to me you wouldn't want it in your heat exchanger. What do you think? A problem or a non-issue? I can fix the joints but wondering how bad a sign it might be.
  2. Sponsored Links
  3. ianmcd
    ianmcd
    15 Aug 2010
    22,831
    Thanks Received:
    9,246
    Lanarkshire
    Country:
    Shouldnt be anything inside the pipes except water and inhibitor
    • Thanks Thanks x 1
  4. Nigel R
    Nigel R
    7 Feb 2021
    24
    Thanks Received:
    3
    Country:
    Thanks, this was my instinct.
    • Like Like x 1
  5. ianmcd
    ianmcd
    15 Aug 2010
    22,831
    Thanks Received:
    9,246
    Lanarkshire
    Country:
    How did it get in there ?
  6. Nigel R
    Nigel R
    7 Feb 2021
    24
    Thanks Received:
    3
    Country:
    My young heating engineer! He's taken a break while some late parts arrive and I picked up the valve he'd fitted then removed. It was full of the green goo, so I undid another joint, to the filter, which is the one in the photo.
  7. Sponsored Links
  8. ianmcd
    ianmcd
    15 Aug 2010
    22,831
    Thanks Received:
    9,246
    Lanarkshire
    Country:
    He is doing something wrong somewhere
    • Thanks Thanks x 1
  9. Nigel R
    Nigel R
    7 Feb 2021
    24
    Thanks Received:
    3
    Country:
    Yes, thanks for your input, it's given me the confidence to do something about it. Looks like I might have tried a bit too hard to support a local lad starting out.
    • Thanks Thanks x 1
  10. Nige F
    Nige F
    28 Jun 2005
    21,200
    Thanks Received:
    1,741
    Country:
    Boss white smears nicely round the pipe in front of the olive - and smells - he will go home smelling like a proper plumber . Not to be used on potable water pipes nowadays;)
  11. ianmcd
    ianmcd
    15 Aug 2010
    22,831
    Thanks Received:
    9,246
    Lanarkshire
    Country:
    To be fair to the lad if he is just starting out, so many so called tradesmen still put flux inside fittings , before soldering, he has probably been showed to do that by someone who hasnt a clue, good that you are giving the lad a chance
    • Like Like x 2
Loading...
Share This Page
