what kind of wiring is this
14 Sep 2021
found this today .. is first double socket from CU into kitchen ring.
grey flex 2x brown and 2x blue with a fly earth looped round one of the grey flex and into socket earth.
Struggling to make out your description and photographs.
Is this not just two regular 2.5mm2 twin and earth cables??
hi sparkwright
No its not
its 2 lots of brown and blue no earth... the earth you can see is screwed in to a termnal on the socket and looped round one of the grey flex as in second pic. the 2 flex have NO earth in them
It's T&E that someone has stripped by pulling the CPC through the outer grey sheath, with both CPCs in the same piece of sleeving.
Hi Flameport
ok both of you have said twin and earth so I will take the whole thing off tommorow and look, theres no lecy to that part of house right now as plasterer coming in the morning so will have to wait for daylight.
Thank you both
Thanks to all who helped took socket off before plaster came it was twin and earth. just confused me as all other double sockets had 1 green and yellow going to each of the terminals.
Dont know how to mark thread as solved if someone points me right direction I will do so.
thanks for your input eflimpudence I will see if my boss will up my pay so I can buy a new camera.
You have done that, with your final post. There is a Thanks and a Like button, on the lower right of each post, which might be invisible until you hover over the area, at least they are invisible on my system..
.... There is a Thanks and a Like button, on the lower right of each post, which might be invisible until you hover over the area, at least they are invisible on my system..
They are not invisible, at least not to me, but they are very feint until one 'hovers over the area'.
