Being doing some decorating/running speaker cables behind walls, and in the process have noticed that the wall lights are powered from a switch which is part of the the ring circuit for the sockets in that room.
This is effectively just an unfused switch with the cable for the light connected to it, so the only fuse for that lighting circuit is the 32 amp breaker in the CU.
Firstly, is this allowable, as to my limited understanding it doesn't seem safe?
And if not, is there anything I can do about it, such as replace the unfused switch with a fused one?
Thanks.
Thanks.
