Hi i have a double socket but i want a switched fused spur. Is there anyway to have a single socket and a switched fused spur in the same double socket pattress box.
True - but I'm not sure what that's got to do with the OP's question about getting both accessories in one pattress box... You can put one of the cables on the left-hand accessory, one on the right, and put a short length between the two, so that the ring or radial continues through them....
Thats what i hoped you could do. What about connecting them to the existing wiring.
You can if you make it up with modular plates eg
https://www.socketsandswitches.com/index.asp?SKSID=840&ItemID=33596
https://www.socketsandswitches.com/index.asp?SKSID=840&ItemID=17394
and any switches or blanking plates needed
Not sure if there's a flex outlet module available.
The problem is you run out of spaces.You can if you make it up with modular plates eg
(I missed thgis comment before!) ... Maybe, but only if you regard around 24 mm (almost an inch) as "a few millimetres".A dual box is a few millimetres wider than its double equivalent
