I need to fit 3 downlighters in my new bathroom and 2 in the adjacent corridor. This is a first floor with loft above, the corridor has a plasterboard ceiling with 270mm mineral wool, the bathroom will have - pvc ceiling cladding, 50mm plasterboard with PIR insulation bonded to it and 270mm mineral wool above.
I have 5 of these light fittings:
Are these suitable, everywhere, or anywhere? The one near the bath I think is zone 2 (and even if just outside it will be close to a rainhead shower).
I think I need to cover- IP rating, fire spread
and the loft insulation. They will be fitted with led "bulbs". I suspect the answer will be that I should use something else (although I'd prefer to make use of them). If it can't be then I'd prefer something with replaceable "bulbs" in case we don't like the temperature or they turn out to be too bright or dim.
As always, thanks.
As always, thanks.
