Dual zone thermostats to Nest E
28 Nov 2021
Looking to fit a smart thermometer at home. House was built in 2016 and has an Ideal Logic 35 combi boiler and dual zone Honeywell CM707 thermostats currently.
I'm looking at Nest E (or v3)
Could someone explain the wiring for me? The A wire doesn't seem too common in installations / wiring conventions and I don't want to get it wrong.
I appreciate I'll need two nests for to it being dual zone but just looking to install one first.
Downstairs stat:
Upstairs stat:
Junction box by boiler
Boiler wiring:
Great to provide photos, but if you’re going for the Nest E battery operated one, then it’ll just be a case of transferring the wires the same, live and switched, so A to Com and b to NO.
That's great, thank you.
What about if it was the v3?
I think she prefers the v3 for looks, so might have that downstairs and the E for upstairs where aesthetics will be less of a concern.
I prefer Nest Gen 3 as no batteries to go flat, however until the remote temperature sensors are released in UK likely Hive is a better on/off option.
EPH do thermostats designed to work with zones, seems up to 10 can be used set as Master/Slaves even with OpenTherm, and the Drayton Wiser on/off mode do a special unit with up to three zones but on/off not OpenTherm. There may be others, but back to basics either remove the zone valves and use linked TRV's or use a thermostat designed to work with zones.
The Drayton has one channel which can work with OpenTherm module, and two and three channel I would think likely needs three channel for two central heating zones even is direct domestic hot water. Plus the Drayton can link to Drayton TRV heads which seem to be around the best TRV heads with algorithms to work out time to heat room so heats room fast without over shooting.
If a job is worth doing, it is worth doing well.
It would need the heat link to be installed by the wiring center (junction box) and x2 heat links would be required.
The Honeywell CM707s are pretty good and reliable. What do you hope to achieve by replacing with Nest?
For me no problem using an oil boiler, which does not modulate, but with gas very different. The big question is when fitting any on/off wall thermostat is will it mess up the boilers built in control system.
Mothers house this 84067_P.jpg was fitted, it would have been very good with this oil boiler, but the anti hysteresis software made it unsuitable for gas modulating boilers.
As the target was approached the thermostat started to switch off/on slowly changing the ratio between off and on so that the boiler average output slowly dropped. Rather clever really.
However the gas boiler monitors the return water temperature and as it increases it modulates the boiler (turns down output) and in some cases also output temperature also reducing hysteresis and more important gaining the latent heat.
Once the boiler is turned off, it in the main resets, so restarts as max output, and if turned off before it has modulated then far more energy held in boiler which is then loss up the flue.
So what we want is for the thermostat to use very clever algorithms and work out what point to turn off so it will not over shoot, and keep the number of on/off to a minimum. However this is hard for it to do, as the TRV is also doing the same thing, and also leaving doors open or closed will also affect heating and cooling times.
So to work it needs the same air flow all the time and no TRV in the system, i.e. hot air central heating as used in USA. I actually had a hot air system in the UK, and there was a vent in every door so air could return to main room, and since air circulated all around the house one thermostat would control whole house, it also resulted in warm air being circulated past single glazed windows so heat loss was silly.
But last house used Myson fan assisted radiator again ensuring a flow of air so one thermostat controlled whole house.
But mothers house and this house has internal doors on all rooms not just bedrooms, 15 areas in all, some very small like shower room and utility room, but to counter for wind and sun and other cooling and heating each room at varying rates using lock shield valves only to proportion the heating will not work.
So most homes need TRV heads to vary the heating for each room, so big question is if the TRV sets room temperature what is the wall thermostat for? Well the TRV can tell the boiler with return water temperature to turn up or down, and even when to turn off, but it can't tell it when to turn on again, so we fit a on/off wall thermostat often in the hall which is kept cool so as summer arrives it will turn off boiler.
OK now for the bit I don't understand, why fit zone valves? OK with my house the flat under the main house not often used, so turning off whole flat makes sense. But within the main house we have a dinning room hardly ever used so turned down heating, kitchen and living rooms used in the evening, craft room and office used in the day, and two bedrooms used over night, splitting heating to upper and middle floors would be pointless. And if done would want it timed not set be temperature. The rooms all come off one central area, hall, stairs and landing, which is naturally an average of all rooms. No other room could be used as a single point to monitor temperature, and to turn off heating in upper floors would cool hall as would lower floors, so it is an all or nothing, either one thermostat for whole house, or thermostat in every room (TRV).
So step one consider why you have zone valves, and are they appropriate for how the home is used? Do children use bedrooms for homework, is the bathroom heated which ever zone is on. Think about it first and ask yourself do I want zone valves the way they are now, or would TRV heads do a better job.
If you go for TRV heads then better if some at least can link to the wall thermostat, which means Nest is not suitable as least until the temperature sensor units are released in UK. Nest would have been great in last two home with hot air circulating but as found out, not this house.
