See above.
I can't see anything that tells you a 48-hour validity last 30 days.
Where did you see it?
See above.
No but I was told that "A Covid Pass" is only valid for thirty days.I can't see anything that tells you a 48-hour validity last 30 days.
What is it about people on this forum and reading what is written?So you didn't see it.
The mind boggles.Why? Do your vaccines become void after thirty days?
Has Boris been writing the regulations?The mind boggles.
Quite enormous potential consequences with a small slip of the pen.A simple and rather obvious slip of the pen. I think we all know what the intended meaning and regulation was. I spotted that error yesterday.
The bit you're looking for is in your own quote. Recovered from Covid. The theory being that having caught and not died from Covid you're lower risk, similar to a vaccinated person.Has Boris been writing the regulations?
I would hope that no-one with a positive PCR test gets a Covid passport.
A positive result means it's likely you had coronavirus (COVID-19) when the test was done. You must self-isolate immediately.
https://www.nhs.uk/conditions/coronavirus-covid-19/testing/test-results/positive-test-result/
Covid passports are a way of proving that a person has been vaccinated against (or in some cases recovered from or tested negative for) Covid-19
https://www.instituteforgovernment.org.uk/explainers/vaccine-passports
Here's the linkThe bit you're looking for is in your own quote. Recovered from Covid. The theory being that having caught and not died from Covid you're lower risk, similar to a vaccinated person.
